Mckim90
Like to put oversized rear and front tires on anyone know which
other allis wheels will bolt on. Also looking for a good used fuel
tank and rear fenders.
How oversized? The earlier D17 used 16.9 tires and the spin out rims would fit your centers. Any old 8 bolt combine rim works too. That gets you into an 18.1x26 or so, but they are set pretty wide.
AaronSEIA
Hey, McKim !! Did you ever get your HP up to 70 HP and the hand clutch eliminated ?? What did you do ??
I have not but did hear from keystone turbos that if you put there
kit on it will double the horsepower of the tractor also the hand
clutch is probably going to get bolted together or I will get
another shaft and bolt the two together in place of the hand
clutch and take the clutch out.
Remove the hand clutch and get a second top PTO gear and install it backwards, bolting it to the gear inside the tractor. Keystone turbo kits lots of negatives and disgruntled buyers and you must use high octane gas.
Yes I have heard the same about keystone more or less your
putting a grenade on it when you put turbos on gas tractors and
yes pto gear.
