mshipman
I'm not sure what this part is called. It on the left side of the motor where the fuel line comes in and another comes out and it has 15PSI stamped on it. On the line comeing in the threads are striped and it leaks. Can i replace this part or possible fix this one. I'm not sure what this part is or what it does. It's a diesel btw.
Thanks for any help.
Is it in this picture?
<a href="http://s1205.photobucket.com/albums/bb436/Jim3501/?action=view&amp;current=Picture-1.jpg" target="_blank">
Picture-1.jpg" border="0" alt="Photobucket
</a>
yeah that looks like it fom what i can tell in the picture on the lower left side.
It has two 7/16" bolts and 4 flat head screws holding it on
From what I can tell in the lower left in the picture it is part of the injector pump. Not a seperate piece with a part number. The line in the lower left side of the picture is a motor oil line to the injector pump.
<a href="http://s1205.photobucket.com/albums/bb436/Jim3501/?action=view&amp;current=Picture001-2.jpg" target="_blank">
Picture001-2.jpg" border="0" alt="Photobucket
</a>
i'll take a closer look at it tomorrow. I do know the fuel passes through it. If you take it off there is some gears behind it.
(quoted from post at 01:32:15 04/25/11) Sorry, I was on the wrong page in the parts books.
It is a fuel supply pump.
# 74506816
you got aby idea if anyone still makes this part. I'm thinking about trying to fix the one i got. Either trying to rethread it or jb weld the coupling in.
You probably won't be able to order a new one. Call an ACGO dealer.
I would try to repair with Loctite-Form-A-Thread.
Follow the instuctions and cleaning is a big factor to success with this product.
Let it cure. Don't rush it.
