WD9 diesel pump
hello
i have been having problems with the pump crankcase filling up with diesel on my WD9. When i leave the diesel tank full when i park the tractor, by the time i go out to start it again, all the diesel has been through the pump and spilled out the crankcase filler tube on the diesel pump. im tired of having a pool of diesel on the shop floor and was wondering if anybody knows what the problem is. Any help is appreitated. thanks
Can't speak to the Allis D19 engine, but I had the same thing happen on the Perkins in my shrimp boat a few years back and it was the lower seal on the injection pump. Had to remove the pump and replace the seal...no problems after that. Don't bump the engine over until you get the pump back in and don't rotate the pump doing the fix or if you get a shop to do the seal replacement, ask them to keep the pump in the same position when delivered...
