Weekend starting out good
David G
I got the new crank sensor in the MH44, and all the gaps set. If you remember, I broke the original when I pulled the engine to replace the clutch output bearing.
I took it for a little drive on the county pavement past my place. It ran great, until the throttle pin fell out. It idled down, then went wide open. I found the pin and put it back in. I think I will put the keeper in.
The drive train is much quieter after replacing the bearing and dumping a quart of Lucas in it. I bought a quart for the Farmall, but cannot find my 3/4 drive breaker bar, used to get the plug out.
I swept floor of shop and got equipment moved around so it is more convenient.
Weed garden and split wood tomorrow if it does not rain.
I need to focus now on painting the hood and grill, hope to get inside coat on today. The torque generator is leaking and the steering shaft is bent, but will deal with that when replacement torque generator comes in later this week.
