weekly tire question
SHALER
I have a light duty trailer with 4.80x12 tires on it. They are only rated for 750 lbs ea. The trailer is pretty study. what other tire size options do I have on that wheel that will be rated for a heavier load?
Really limited to what you have unless you go to a bigger wheel.
Check the lug pattern and hub diameter, see if you can find some bigger wheels. You might can change the hubs, depends on the axle. If you can find something in the 14-15 inch size and will still clear the fenders, then you can get away from ST (special trailer) and go with LT (light truck) or standard car tires if not hauling a heavy load.
If nothing else, the larger diameter will slow the tire down, much easier on the tire at highway speed.
I am with the other guy on this. What is the axle iteself rated at? My trailer that came with 4.80 x 12 tires on it was only rated for 2,000 lb. And even though I don't think I ever had more than 1000 lb. on it it is getting sort of sway backed.
You can try metric size tires 145/R12, or 145/80-12 its a little taller by around 3/4" . I found several from 1100-1500lbs load capacity
