johndeeregreg
have a 720 diesel with factory wide front, 16.9-38" rears at about 40% tread w/o fluid and a F145H 4-16 plow running about 8" deep and in second gear with the high speed transmission. plowing in SE MN black dirt. i know there is a lot of variables but how much weight would you put on to start with and where?
last year with same rig i had 4 wheel weights in each wheel and 600# hanging out front. hard to tell how much slippage there was but i don't think it was much and the front end seemed to stay down just fine. don't want to go over kill but don't want to spin out all day either.
also this year i will be using the center link draft sensing where as last year i was not, not sure if that makes any difference on how much weight i would need on the front or back for that matter? if i'm thinking about it right in theory if the front never comes up and the wheels never spin to dig down and change the relation of the tractor to the plow the draft sensing will never adjust depth? it would just keep the plow where it is and lug the engine down more correct? or is the sensing more sensitive than i think it is? also what hole would you run the center link in? maybe i'm just thinking to much.
