Weird behavior on two stage clutch
I recently purchased a 1962 MF 35 Diesel (Perkins A-3) with live pto. The clutch wouldn"t engage the pto so I adjusted pedal and the clearance on clutch fingers. Now when I push clutch pedal down this happens.....push down a ways to disengage tranny gears.....push down just a bit more and pto disengages....push down all the way to foot rest and pto/gearbox makes strange noises and re-engages pto?
What did I do?.....never had this happen on any of my 6 MF35"s I have owned before.
The clutch fingers are hitting the PTO clutch. Back off on your outside adjustment , giving it a little more free travel. If they still contact you may have to adjust your PTO gap again...What thickness did you set you PTO at??? You will probebly be ok setting your free travel.
Did the freeplay adjustment help?? 60 is about right due to wear. you may need to bring it out if the outside adj, doesn't help.
