Welcome to the crib...
kcm.MN
Location
NW Minnesota
Puzzle: https://jigex.com/hjGnL
Each side has gaps between the boards up past the door opening.
That is how all the old corn cribs here were built.
Except that is a large one.
because of the cupalo on the roof houses the top of the inside elevator that moved the corn from the wagon up and then dumped it in the two side cribs in the middle were bins that stored grain overhead of the driveway. The open slats on the crib let air low thru and dried the earcorn which was either ground for feed or shelled for feed
Yes, and some had more granary space. my father in law has 3 cribs, I believe each has 4 granaries above the center drive? A lot of wood went into building one of those.
