Well, I spoke to soon about no broken wires. I started taking the diodes off to test them and got the top two off. I then started to loosen the bottom diode in the back and I heard something drop to the bottom of the case. I had to take the back cover off of the welder to finish getting to the bottom diodes. I then saw that the end of the wire that connected to one of the diodes had broken. I went ahead and tested three of the diodes in the machine. I probably should have tested the fourth diode, but didn't. I can still do that, but with the broken wire, I'm thinking that the wire is the problem and not the diodes.
The one picture is of my multimeter. I tested on both the 200 and 2000 settings for ohms on the meter. At the lowest setting I was getting over 100 in one direction, and in the other direction I was getting nothing. At the 2000 setting I was getting between 1200 and 1600 in one direction and nothing in the other setting.
I am a bit confused though. The reading was not constant when I was testing the diodes. The meter would read a number then go to nothing. Is that normal? I was expecting it to read a number and stay there. There was never a reading in the opposite direction.
