Usedtobeiowadave
House water supply is a bored well 75' out. 220V pump 60' down on plastic tubing hanging on a pitless adapter. Pump is about 10 years old, the it replaced lasted 30. Tubing and wiring inside the pump case were replaced along with the pump. No water on this 96 degree day. 220V incoming to the Pumptrol switch, 220 outgoing when I lift and hold the switch lever. At the well head, no current with clamp ammeter when wife lifts and holds Pumptrol switch. At the well head, momentarily reads 220V when she lifts and holds Pumptrol switch. Thinking broken line between house and well head, but why would it momentarily read 220V?
