Wet fuel pump
The fuel pump on my International B 275 stays wet even after the engine is cleaned.
I've noticed no leaks but, apparently there are.
Fuel has dripped onto the ground under the pump killing the grass.
Is this normal? Is there a gasket set or a fix for this?
Thanks.
LOTS of places they can leak, past the throttle shaft O-ring is probably the most common.
Bob is right, several places could be seeping fuel. Best in the long run to reseal the complete pump and be done with it. Been seeing more drive hub seals leaking fuel into crankcase too.
