Mike(NEOhio)
- Location
- Newbury, Ohio
Cleaning out the bench in the shed and something tells me I should know what they are. Nail heads have numbers too.
That's exactly what the spikes are. The disc may be but I've never seen those.Look a lot like railroad date spikes to me.
They have the year the wooden cross tie was installed.
Railroad spikesLook a lot like railroad date spikes to me.
Cleaning out the bench in the shed and something tells me I should know what they are. Nail heads have numbers too.View attachment 116306
Agree, the tags are a numbering, location system for utility poles.To me they look like Date disks and spike fasteners used to date Electric poles
Not a spike as in holding the rail to the tie. These are date nails driven into the end of ties to indicate inspection date.Looks like they are on a table saw. So not as big as RR spikes.
3 inches long?
Like mentioned some way to I.D. RR ties or utility poles or maybe even to I.D. logs going to a mill so that the harvester gets credit? The last is a big maybe.
You are correct, railroad tie spikes have a flat side and longer.Not a spike as in holding the rail to the tie. These are date nails driven into the end of ties to indicate inspection date.
By gosh you're right. Not long enough for rail spikes. Good catch.Looks like they are on a table saw. So not as big as RR spikes.
3 inches long?
When the utility company replaced poles across your farm you could buy or have the old ones to use as fence posts or to build a hay shed. My neighbor even saws them for lumber with his sawmill.Only about 2 inches long and the tags are copper. I'm inclined to believe they're from utility poles. Why would they be on an old dairy farm.
I have a pole out back with a date stamp of September 41.Used For utility pole inspection dating.
Back when those were used. Power pole numbers were nailed to the pole individually like the metal numbers people use for mail box post or house numbers.
We used to give them away. Sometimes even help load them for you. Environmental standards changed and now we have to cut them up and pay someone to dispose of hazardous waste.When the utility company replaced poles across your farm you could buy or have the old ones to use as fence posts or to build a hay shed. My neighbor even saws them for lumber with his sawmill.
I could tell you a story about the historical things two friends I saw in VA. We took a little hike from Doswell to Gordonsville along the railroad tracks in the mid 90s. Passing through Beaverdam, Bumpass, Mineral and a couple of other towns.I have a pole out back with a date stamp of September 41.
