What could be causing this hydraulic chatter?
Farmer Pete
I have a JD 410 with a front end loader. If I leave the loader down overnight then the next morning the hydraulic system chatters like mad for about a minute - sort of like it has air in it. If I leave the loader up overnight I have no problem the next morning. Any guess as to what could be causing this?
The chatter is the sound the main hydraulic pump makes when it's starving for oil. It is basically normal of just about any Deere to do it once it's has some wear. Could be caused by a combination of things; e.g. worn transmission, worn stroke-control valve inside the pump, etc.
Stroke-control valve in the pump is the most common wear item - and when it's starts leaking, often makes the tractor start hard also.
