what gear ?
Depends alot on the hay and the condition of your cutter. In the right conditions, I could cut in 4th with my M and 7'balanced head mower. other hay was 3rd, or even 2nd...
Ben
the problem im having is the orchard grass gets caught up and sickle want to ride up on top skipping sections i was mowing in first so do you think i need to go faster then the blades are some what sharp no nick or ding in them also do you go full throtle
My 5-speed Ford I mow in 3rd or 4th gear.
I'd try a little faster - 3rd maybe?
But it depends on the grass, moisture, etc. And condition of the sickle & ledger plates - which you say are good.
--->Paul
Is the hay standing good or is it down flat, if flat in spots it will be normal to want to slide over the spots that are leaning the way you are traveling. If that is not the case then you have cutter bar problems as in bad sections, guards or wear plates and hold downs or knife is not in register. Third gear should be about right in heavy hay, 4th in lighter hay and close to pto speed of 540 rpm.
Sounds to me like you need to go faster. Around three quarter throttle to keep PTO speed up
