What i have been working on....
Well here is just a few pictures of what i have been doing. Trying to get the motor back together by the 19th of june....not sure if its gonna happen by im gonna try.
anyone ever build their of side sheilds? might be doing those in the future.
let me know what you think...please keep neg. comments to yourself.
thanks..... i hope i get it together to! i love the big tire look on these tractors!...i know you more than likely are competition for me but just wondering allis puller to allis puller....how does your tractor do with the bigger tires? im really worried about rpm/speed/ and if im gonna have enough snort to do well.
just wondering if you power out or gearing wise how you do..is urs a wd45 or wd.not sure if there what a ratio diffrence in the two but im running 13.6x38"s
I have a wd45 diesel rear. same as putting in a early d-17 ring and pinion in a wd45. With a 15.5-38 or 13.6-38 at stock rpm 1720. I run about 3 mph in first. with a wd45 rear it should be closer to 3.5 mph. I highly recomend buying the Antique tractor pull Guide and the second one Ground speeds and gearing. Very informative on alot of tractors.
Mine usualy spins out when I hit about 1.4 mph. By them my front is up in the air. Also there is alot of casting weight diferences in the front end of these wc,wd,wd45"s..
