grandpa Love
Bought a Cub yesterday, this was on the floor pan, seller said it went with it?? Nothing I've ever seen?? What is it? Not cub for sure!
It is a sheet metal hole punch (about 5/16 diameter. We cant see the bottom die holder to assess if there is a corresponding die for the punch. The punch is forced downwards toward the die by a screw thread in the area under the handle socket. this probably could handle 12 gauge mild steel sheet, maybe 14ga.
The bolt heads next to the punch are a stripper that pushes the punched metal off of the punch head. Jim
Whitney No 20-1 punch
Can punch a half inch hole in 1/2 inch thick hot rolled steel.
Up to 13/16 on thinner stuff.
The shallow throat limits where you can punch to about 2" from material edges.
