What is my tractor?
Dylanh
Hi guys, I have been trying to determine what exact model of tractor I have. It was traded to me as a case 530. Some items I see don't make sense and just wondered if anyone could shed any further detail as to what I actually have. Thanks.
Dylan
As soon as I'm unrestricted I will post photos
Hello Dylan,
Ok, have you found a serial # plate? It would tell you what you have, if not there are a lot of great people on here that will help you
Dan
The only serial plate I have found intact was on the engine. It is 2062488. It is a single range 4 speed transmission? The shift pattern casting is as follows
S13
R24
It also has a secondary hand clutch by drivers left leg.
Judging from the pic. it is a 530 tripple range, with DOM 3pt. The 530s and 630s had full fender, as in your pic., but no 630s had DOM hitch. A 430 would have shell fenders and bat. located up in the hood, and smaller fuel tank mounted within the hood.
Loren
Thanks for the info Loren. What does triple range mean? I would assume high, med and low but I don't see any type of range selector on the tractor.
Dylan
If there is no range shift lever to the RH of the tranny cover under the battry, which after looking at your upside down, smart phone, HeHe pic again, I don't see, it could be a straight 4spd. I didn't know any were built that way, but I have learned to never say never, when discussing options on Case tractors.
Loren
