Yomamas113
I have a IH front end with the motor that the guy I bought my house from left just wondering what it’s worth and how I could sell it
It's a power unit/industrial engine.That's not a front end it is a power unit. It's the engine part of a tractor that would have been used to power a hay bailer or something like that. I'm not sure which model it is from your pictures but if you search for images of IH U1 or U2 power units you'll come pretty close. Look for a silver and black colored tag for the serial number and model number. That tag might be on the clutch housing.
Dave
Yep, grandpa had the IY69 on his 62 & 64 harvester thresher.Yes, it is a Power Unit. However, it is not a Cub engine. In fact it is not the engine from any IH tractor. It was built by Continental. IH bought engines from Continental and added the surrounding pieces so it could be used to power a machine. You may find a Continental tag on one side or the other of the engine block. The gear-reduction clutch strongly suggests it was originally on a small combine.
The Vari-Speed governor was not originally part of the unit. If was probably installed when the then-owner couldn't get the original governor to work. The original governor is still there (just ahead of the carburetor) but all the linkage has been removed.
Do a web search for "Continental engine IY69" for pictures of others about like it.
I'm just guessing but suspect it is just a speed limiter. This type governor was/is installed on trucks to limit road speed. Note that this engine has now got a speed control knob that is connected directly to the carburetor. The vari-speed has its own butterfly to limit engine speed even with the carb pulled wide open.Wonder if the vari-speed thing is for a welder?
Wouldn't have the clutch then.
Jim
There is a free Classified section on here under Marketplace I will link it. YT classified You have to select a section to place an add, probably be parts.Thanks for all the replies it has the hand crank with it and I turned it over with it so I know it’s not frozen up but I don’t know what it’s worth or how I would go about selling it as I have no use for it
Any ideas on its value and how to sell it as I’m not a farmer
How much it's worth? Honestly, not much, especially not running. Even less if the engine is seized and doesn't turn, but luckily that's not the case. The engine doesn't fit any tractor that I'm aware of. Someone with an old 50T baler or the small pull type combine that uses that engine would be the likely customers, but those machines are extremely rare, and they could also use a Cub engine.Thanks for all the replies it has the hand crank with it and I turned it over with it so I know it’s not frozen up but I don’t know what it’s worth or how I would go about selling it as I have no use for it
