I've had more gremlins on reassembly than any other area of the Jube's rebuild.
Put the hydraulic drive gear on, four bolts wouldn't torque. Felt them slipping, one actually stripped. Checked the manual, supposed to be 5/16 x 28's. Not these, these were 1/4 x 20's.
Bought four new grade 5 bolts, ran a tap in to clean the threads and reinstalled. They torqued ok.
Installed the flywheel tonight, installed the clutch assembly. While stagger torquing the pressure plate bolts to 12-16 lbs, one bolt broke, caused the pressure plate to pop loose and broke three other bolts. Four out of six broke off.
Now I've got four bolts to drill out.
Probably should have bought new pressure plate bolts while I was at it.
