what model is my david brown
jean kulig
Hi, can anyone help me? I have a david brown tractor but dont know which model.As you look at the tractor from front there is a number on each side, rght side on engine is F925103 H2, on left F904010 both embossed, also on left is a stamped number on a block approx 3" x 1" 449001 and 10332. Thanks for any help
hi jean your tractor is a db 990 selectamatic with a 4/49 engine i think the numbers f925103 f904010 are only casting numbers or mould numbers 10332 is the engine serial# the tractor serial # can be found either on a plate on the tool box or the front axle carrier on a flat area just between the front of the engine and the radiator on the right (the same side as the starter motor),these munbers will give some info on age if you could post these numbers i may be able to give you a build year hope this helps tom.
