What plugs for a 620?
tomstractorsandtoys
I have a neighbors 620 in the shop. A year ago someone dumped a jug of gas in it that was over two thirds water. Today I removed the fuel bowl assembly and pressure washed the tank. He wants a tune up done as well. What brand plugs do you recommend for a 620 that gets three hours use per year? He might haul half a dozen loads of manure with it and they have a church picnic each fall at the farm and they give a hay ride with it. Thanks Tom
If you go with a Resistor plug the Autolite 388 is a tad hotter then the 386. For light duty infrequent use especially if the engine is showing its age and exhibits some plug fouling, I like the hotter plug.
If you go with a Non Resistor 3116 is in the heat range of the two above.
What brand of spark plugs or oil is best can draw a ton of different opinions.
John T
"[b:654c4848f0][i:654c4848f0]Autolite 3116 non resistor[/i:654c4848f0][/b:654c4848f0]"
Agree.
We use them on our Model 70s.
