What to build
2150
How much horsepower can you get out of a 3208 cat with a 2.75 inlet charger Apump and 2800 rpms? Those are the rough rules for a local open speed class
Also how much hp can you get out of a 478 herc? rules call for 2800rpm max across the bored and turbocharger with a 2.330" inducer bore restriction within 2" of the face of the intake wheel. and can either run the stock appearing pump or upgrade the a P7100.
2 different clubs just don't know what way to go. Both clubs have to run stock block so the 8.3 cummins is not an option
The question is more on topic than a lot of other posts on this page.
To the OP, the crowd here is probably not the right audience for your question. There are only a few die hard pullers here and most are not into enhanced diesels. I would suggest either exploring some of the facebook pulling groups, or the forum at Pulloff.com. If you do ask on pull off, make sure to put your fire suit on before reading the replies. That crowd likes to flame, but some good information can seep through.
