What Tractor Does this Carburetor Fit?
RTR
Cleaning up and I found this sitting on the shelf. Any clue on what it might fit?? I thought it was a Farmall M carburetor but the flange is 90 degrees off for that.
Next to last pic. There is a round piece next to the mounting flange that has a number on it. IH used that same round piece {usually brass} on a lot of their carbs. That number then will relate back to equip. that used that carb.
(quoted from post at 18:44:33 04/10/20) Next to last pic. There is a round piece next to the mounting flange that has a number on it. IH used that same round piece {usually brass} on a lot of their carbs. That number then will relate back to equip. that used that carb.
Looks like in the picture it could read 531932R91 ?? I ll try and look that up.
Part no. suggests IHC, by the way the choke and throttle are operated suggests Models A, B, C, or industrial versions of 113/123 engine. Also possible is the Continental
industrial used on baler, combines ect.
I was wrong. The part number on that disk is 534932R91. Someone said that it fits a 715 combine but are there any other tractors it fits? Maybe Even other brand tractors that aren t IH ?
