What tractor is this?
Tgrasher
A guy has the 38 tires with rims for sale and I'm wondering if the rims would fit a Case with 38 rims. The Case has a double raised rib with eight clamps holding it to the wheel as the top picture shows.
Double bevel rims were fit to most tractors from the late 1950s through most of the 1980s. If they are double bevel rims they will/should fit.
Place particular attention to the antiroation bump on the rim,as it has to lock at a certain point on the hub. Tom Turkey dealt with that issue several years back on his Case 400 Racine.CM
In the Case picture you can see the two top clamps are different from the other six. Those are the "fixed" clamps that register on two of the bumps in the rim. You hang the rim on those two fixed clamps, and then install and tighten the other six clamps to make the rim run true.
Double bevel rims are industry standard, so as long as they have the correct diameter, they will fit.
I bought this 730 Case tractor Tuesday and am going to haul it in today. I should be able to find out how bad the tires are when I air them up. They have been setting flat on rock/dirt for two years and have open cracks where they bulge out on the ground. The other tires/rims for sale are half the price of a set of new tires, but are about four hours away. As the tractor sits in the picture, it looks like the guy is restoring it, which makes me question why he's selling the tires/rims. I'll have to find out more with pictures before I gamble on these.
