What year is this? Second attempt!
rjmt
Can?t find the s/n.
It's probably covered by the paint. It should be stamped on the flat spot above the starter housing.
Golden Jubilee and NAA Ford tractors: produced from 1953 to 1954
On early production models, before serial number NAA-22239, the serial number is located on the left front corner of the engine block, just below the manifold. On models serial number NAA-22239 and beyond the serial number is located on the left side of the transmission housing, above and to the rear of the starter, just below a 3"x 6" horizontal flat on a 3/8"x 3" semi-vertical surface. The serial number is hand-stamped onto the semi-vertical flat, not cast into the transmission housing. Format is model designation (i.e. "NAA" or "NAB") before sequential production number.
