What's it worth? 1948 Case VA
Valdfur
Saw this on marketplace, it's not running and hasn't run in about a decade. Guy doesn't have a list price, so he probably wants too much but I'd like to know what it's worth
Not running could be as simple as new points and a battery or as bad as a lock up engine so hard to say for sure. I picked up a Case VAC for $300 a few years back that didn't run but drove off the trailer
Upvote 1
I am a CASE man , And I like My VAC for running the auger ,,. its a great Great trailer tractor and i keep it hooked up to one most the time ,. This is a VAI , to my best knowledge , We had one growing up , My mother raked and baled hay with it . Evaluating this VAI , cost wise ,,. condition of tires , running , running Well , Restored Well , All are a big factor ,, Dont forget to inspect the wheels for saline damage ,,.This VAI has a lot going for it ,muffler and rain cap ,. straight tin , good tires and WHEEL WEIGHTS , aged restoration repaint , belt pulley ,PTO, and hydraulic lever lift , and it has front lights, looks like original 6 volt system still intact . Running this tractor could command 2000 dollars by 2 motivated buyers at auction ,,, However a tinkerer wont pay much over 1200 assuming the wheels and tires are in good conditin , Not running 5-700 tops , If the seller declares it ran great last fall LOL.. pulling this out of the bushes with low or flat tires as complete as it is with a rain cap 350 dollars , that is what the value is in Southern IND .
Upvote 1
Thanks! It seems pretty valueless, it should have a handcrank so it would be easy to tell if it's locked up or not
Upvote 0
Thanks! That seems about right, I didn't realize it had some desirable pieces.
Upvote 0
I had a clean, attractive, and running, '43 VAI go for $2,100 at auction 2 years ago (this very weekend). with only a spare side-belt PTO kit (not installed) and lights/horn as enhancements. Non-running and unknown condition drops the bid dramatically.
Upvote 1
What are those ams/levers on either side of the gas tank? Could they be rockshaft arms like a Farmall C?
Upvote 1
They have the advantage that you can get on and off without killing yourself. Bad spot is side of block
where farmers forget to drain the water and it freezes. Easily welded, but requires complete tear-down.
I had no trouble finding engines or parts. In my opinion, the design and engineering deserve prizes.
Upvote 1
