What's it worth?
grandpa Love
Ain't 2 million! Lol. However it made me look. Cracked block? Scrap value, maybe? My wife is giving me the evil eye......I need another project! .
Its on Facebook market place. In Central AL. Other pictures show hood,grill, and such removed. Possible to weld a block? I guess it depends...... ..
depends on where it is cracked an how bad. I think the block from a S66 might be the same as same size tractor, just row crop instead of utility. Would fit right in with your Fords for use.
If it is as nice as the pictures indicate, why was it taken apart? If all it needs is the sheet metal re-installed, why did they not already do that? Smells like a scam to me.
Wow! That's not even the same tractor! Look at the removed hood. That was the first thing that stood out. Lacking in the sheen department. Then the yellow coming through on the front rims & the rears aren't the same. Caveat emptor, my friend.
Mike
That is one I have always wanted but never found but with a cracked block that can be a big problem depending on where it is cracked. I'd offer maybe a 1/4 of what there asking for it unless they provide a good block. I can tell you this side by side it is a better tractor then your 960 is
Its a tough call,if you need another block then the paint won?t match even if you paint it first,$2000 is pushing it in today?s deflated market with a cracked block.
First pic name from tractordata. You can see it right in the corner, well the data part. It does say that the first pic is whats its suppose to look like "put together".
So the first picture is of one at a show somewhere with no connection to the seller it seems.The one in the 2nd picture is one he has,I like Olivers but not fan of the S55 or 550 tractors I'd offer $500.I have a motor in a parts 66 that ran good and also have a diesel out of a 660.
