That's your "parking brake." I agree that they don't work very well, if at all.....of the brake pawls, located behind the hydraulic inspection covers. I have never seen how they are useful.
Yeah, the guy that designed it didn't think it through.Mine keep the tractor from rolling away if I leave it running and get off. You have to be pretty flexible to set the parking brake but you step on the pedal and engage the pawl. To release I just tap the pedal hard and it releases. There was an aftermarket company that made a handle to help engage them, been discussed on this board before.
I find them very useful, work perfectly and use my right side one whenever I want to get off the tractor but leave the engine running.....of the brake pawls, located behind the hydraulic inspection covers. I have never seen how they are useful.
We had never used the parking brake feature and they were stuck on both tractors. A little PB blast and tapping with a small freed them up. I couldn’t get them to catch very well. The teeth may be wore down or the anchor plate may need to be moved if possible.Tall T's "Keep those levers clean, oiled lightly and free to drop back down" is the secret! They often need heated (so you can get them apart), taken apart, cleaned, oiled & put back together when I buy another old Ford.
Or the teeth are often filled w/dirt, grease & old paint!We had never used the parking brake feature and they were stuck on both tractors. A little PB blast and tapping with a small freed them up. I couldn’t get them to catch very well. The teeth may be wore down or the anchor plate may need to be moved if possible.
Ns dont have rods to pull, have to toggle with finger/thumb.The ones on my 960 and 901 both work just as you would want. The operating rods were lengthened from 8N length, so the pull loop is up at seat level.
N tractors just dont have a rod to compare with. There is just a simple toggle as shown in the pic above. No handle, no rod.The operating rods were lengthened from 8N length, so the pull loop is up at seat level.
It is to keep the N from rolling down into the deep county drain with a wagon. Uncle could tell you. Not sure if he was on it.....of the brake pawls, located behind the hydraulic inspection covers. I have never seen how they are useful.
