Mike(NEOhio)
- Location
- Newbury, Ohio
72 three cylinder. It's always been a solid runner. Using it the last few days to mow a 9 acre field with lush grass. Several hours in 3rd at 1900
RPM and running great. Went to ted, adjusted the depth, got on to start in and it just died and would not restart. I pulled the coil wire and had
good spark, replaced it and it fired right up. Thought maybe the wire got loose. Next day I raked about an hour then went back to the field mowing.
It ran good but seemed to be laboring a bit. Nearly two hours and almost finished it started sputtering and died in some heavy grass. I pulled the
carb drain and had good flow, got it restarted and finished up. Heading back to the shed and slowed up and it would not idle, died again. Restarted
then it ran good. What should I look for, sediment bowl it clean. I'm thinking something in the carb. Holley and it's been trouble free for me but
it's a long time since I had it off to clean, 15 yrs maybe.
