Wheel Bearings / Genius Plow
Hi , I've got three Little Genius plows of three different sizes and ages . They don't have bearings unless you call the "chilled " bearing a bearing . All they have is steel on steel . There's a separate sand band on the inside of each axle that's greasable and the wheel box that's greasable . Both ride on the axle but the sand band doesn't turn like the wheel box does . There's a wear washer and a step collar inside the wheel box to adjust for wear on all three axles . If you have bearings then it's not a Little Genius as far as I am aware of . So , to answer your question , no leads on wheel bearings . Good Luck ! ...Randy
Thanks Randy,
I noticed that one wheel looks like it might wooble a bit and just assumed it was a bearing deal going bad.
Thanks, I will check the nut and just keep greasing it.
