dexterfarm
I just got a case wrx 301. used it for the first time and the wheels are set real low they bend the tines over a lot. I used the hydraulics to hold it up some to finish raking but of course that is not real even. the springs are very strong and hardly flex at all with the weight of the wheel. there are 2 holes in the arm where the spring can be attached. I am guessing the hole closer to the pivot will cause the spring to stretch more. is that what this second hole on the bar is for. it has no where on it seems it has never been set that way.
second question how do the hydraulics fold the rake out evenly there must be something that splits the hydraulic flow. after I used it I noticed when folded in one side cylinder is not fully in by a few inches and the other one is. will this continue to get worse with use or will it correct itself and even out.
