Wheel studs
Tau44
I have a 1976 1066 international. Somehow six of the eight front wheel studs came out today while I was mowing. I don"t know if they were lose or someone helped them get lose? What size, length, diameter are the front wheel studs
on this tractor. I can"t take one out to measure because two are half out and barely holding on the tire. I stopped the tractor just in time today. Any help would be greatly appreciated.
Les
Why not jack up the hub with the missing/broken studs and take one of the remaning studs for a measurement? You need to take the wheel off to inspect the holes and I would replace ALL studs and you might need a new rim. Also inspect the hub for damaged threads. If everything is in good shape than recenter rim on hub and tighten nuts evenly so as not to bend rim. Lastly spin wheel to be sure tire runs straight and true before removing jack stand and jack. Any guestions? Armand
