Wheel weights and chains
John730911
How do you know what size wheel weights you need and chains?
I have seen some for sale on FB Marketplace.But I want to make sure I have the right ones.
(quoted from post at 16:43:39 01/19/22) How do you know what size wheel weights you need and chains?
Chains you need to check your wheel size and compare to what the chain places show. Chains will gouge up your pavement if you have that, they make rubber strap 'chains' to protect the driveways.
Weights ... I'd start with liquid filling rather than bolting on cast iron. My MF35 came with filled tires from the prior owner and seems to be blue car window washer fluid, which some use instead of chloride that rots the rims out.
The best option is the beet juice residue. Youtube Tractor Mike channel had a segment on beet juice. I haven't investigated it yet but looked promising and better performance than the washer fluid way.
Chains are based on your tire size, if you can find the half round weights they will bolt up on your rear wheel assembly.
