wheel weights for rear tires
Shouldn't need wheel weights if the Traction Booster is working unless ground is really hard. I've seen WD45 wheel weights on ebay. I have a full set on my WD45...I got them for doing some work to a buddies tractor.
(quoted from post at 21:26:49 02/21/12) I have a "57" WD 45. I need wheel weights for plowing with a 3 bottom. Any help where available would be needed. Thanks Jim
You should not need wheel weights. With an AC mounted plow, the plow pulls down on the tractor. One of the sweetest plowing machines I have ever used.
Not trying to hijack the thread but I"m in Indianola Jim and might be interested in those wheel weights if you still have them. I assume they will fit a standard wd?
(quoted from post at 05:46:31 02/23/12) Not trying to hijack the thread but I"m in Indianola Jim and might be interested in those wheel weights if you still have them. I assume they will fit a standard wd?
He doesn't have any...he is wanting some. Shipping may be high but they sell them on ebay all the time.
