wheel weights wanted
Good luck finding them. I watched in the Photo Ads parts section here for about 6 months and found a set for my 240U close enough to go pick them up. they were about 230 or 240 miles from me. They actually came off a B, but was told they would fit and measurements seemed to confirm that. I finally got them mounted just today, before any snow. I pulled the neighbors old cemented in mailbox post out of the ground a couple weeks ago and it lifted the rear off the ground. Maybe it wouldn't do that quite as easy now. That neighbor helped me lift them on today.
You should not have much difficulty finding a set if you have the 28" two piece rims. Just about any IH will fit. I have one set of factory two piece weights with another one piece weight on top. I had the one piece on my H.
If you have the 26" one piece wheel, I don't know about weights for those.
Dell
(quoted from post at 06:38:28 12/09/10) Will weights from a A work?? What are they worth???
I don't know for sure about a 300/350 wheel, but if it is "dished" and 28", with a 9 1/2" square bolt pattern, I think any of the one piece or two piece from an A, B, or 240U and who knows how many others, would work. These I got from a B fit perfectly, and weigh about 75# each.
