Wheel weights
bobo641
I have a set of wheel weights for a Farmall Model A tractor. I am trying to mount the right side but cannot get the bolt from the rear because the length needed hits the rear axle. Any suggestions on mounting he wheel weights
Remove the wheel, put the bolts through the holes in the drive plate, mount the wheel, then put on the weight and nuts. It sure helps to have both a helper and some kind of hoist to lift the weights.
You can loosen the rim-bolts just enough and then wiggle the rim over to give you the room you need. Crib the axle safely. Don't use cinder-block.
