Thought that when first looked. But tire has 34 on it and wheel is for use with a 34. Way made on outside I would guess use with special equipment of somekind.Those are not weights that’s the heavy hub when you have the 23.1-26 tires
So the 4 bolt holes in bottom picture that face rim will match the top wheel weight holes if reversed and mounting bolts go through top wheel and thread into holes in weights? Makes sense but can't find the part number that he shows.600-650 parts book
This was the “heavy option” that heavy cast center with 23.1-26 rim and tire. Not sure how that’s bolted together. And yes those are heavy. I have that setup o. A swd9 and I have another set I plan on Putting on a swdr9.
Big tires are cool![]()
