I viewed something on the internet the other day where a mechanic who maintains JD riding lawn mowers suggested that a person NOT change your oil in a riding lawn mower in the fall - just let the old oil sit in the engine all winter. Change the oil in the spring. Reason: if oil just sits in engine all winter, the viscosity is not maintained - the oil breaks down.
This was sure new to me. If oil sits in a plastic container, or a cast iron engine, I don’t see how oil would be affected. Even bulk oil (I think) still comes in steel barrels. The only difference I see is that a barrel or plastic bottle is air tight – an engine is not.
I still maintain that if I am not going to use an engine for a while (like over the winter), change the oil, start it and let in run a few minutes, then put it away. You will be all set to go in the spring.
When do you change the oil if your car, lawnmower, etc. is going to sit for a while?
