where do i find the Alternator
where do i find the alternator on a polaris 2000 polaris magnum 325 and what is the easyiest way to remove it also where is the fuel filter located
There is no alternator. The battery is charged by the stator which is located under the flywheel on the right side of the engine. If you have battery charging issues, the problem could be something other than the stator. Your dealer should be able to perform a 10 minute test to find just what the culprit is. Sometimes a better option than throwing expensive electrical parts at it which cannot be returned.
The fuel filter is an in-line type and can be found by starting at the fuel shut-off under the tank and tracing the fuel line until you find the filter.
