Where do I get one of
SVcummins
These studs for the starter takes the power inside the starter from the solenoid
Napa has them as part of a kit Part #: NOE 6551143
Dorman does also.
I have brazed, or silver soldered them then filed them smooth, in the past. I have also filed them a little and turned them 90 deg. in a pinch.
I could maybe just use a bolt Ive replaced this once before and then just some rubber or plastic washers
I have been using the long coupler type all thread nuts on my starters rather than the short nuts as the long ones avoid stripping the threads.
This isn’t on the solenoid it’s the field stud into the starter . I have started using coupling nuts as well but this is metric and the only way to get a metric coupling nut is to order one can’t find one locally .
Yes, The old turn 90 degrees, makes sense in many cases. I seem to have accumulated a small pile of "junk" Delco starters over the years and have found my self robbing/salvaging parts. Recently had a discussion with a parts guy at Car Quest, they recently merged with Parts Plus and it haven't improved them. He insisted they didn't have a solenoid for my MF 65 diesel starter. I finally convinced him to bring out the only Delco solenoid they had in stock. It was correct but he claimed it would not fit. Works fine.
Do you have a starter rebuild shop near by. I can buy any parts I need like that from them. The big stuff I buy here.
