FlatFenders
I frequently have to add water/antifreeze to my Ford 600. The radiator and screen are clean and the engine stays cool as long as I keep the radiator full. I don't see any bubbling or signs of a bad head gasket when running with the cap off. The water seems to be flowing normally telling me the water pump is working. I cannot see any leaks anywhere. There is no steam and no sign of water vapor in the exhaust. The engine runs smoothly and has lots of power. I added an overflow tank to it, but not sure if the radiator and cap is capable of dealing with an overflow tank. The overflow tank level never changes so it is obviously not functioning.
I probably should borrow a pressure tester from Autozone next. Is there a cap that will allow it to work with an overflow tank available?
