Where to locate part
TO30 1951 model. The linkage that connects the governor broke where it threads into the part surrounded by compensating spring. I looked on YT parts page and could only find the spring. Any suggestions? The threaded rod broke off about an inch from end of rod and I might be able to find someone to weld it together but its not that big of a rod.
Its very hard to identify what specific part you need without a part number.
If you go to Agco parts books online and find the TO 30 parts book, and the specific part you need, get its part number, and let me know what it is...I may be able to help you out.
I had a look myself using your description and came up with part number 181567m1? If this is the correct part you need, it is still available from Agco. About $10.00.
However I am not sure if it is the one you need or not.
Check it out and get back to me. If the part you need is NOT available from Agco...Sometimes I can find it somewhere.
Wayne
(quoted from post at 17:16:58 06/12/15) Its very hard to identify what specific part you need without a part number.
Wayne
his is exactly the part, thanks so much. I think I have learned I can remove the ball joint end off the broke shaft and just get a threaded rod that the ball joint will fit onto and make it work.
Is the part you require on this page? Taken from FERGUSON REPAIR PARTS LIST
FORM NO. 693 041 M2
Bob....
