Which Case fluids?
I know that it's been talked about already what to put in the COM. I am planing on Valvoline MaxLife Dexron 3 in mine. Is there something better? Also what do you put in the injection pump? The manual tells you to put the same weight oil as the crankcase which is 15w40 is this to thick for the pump?
Don't use valvoline max life it has seal softeners. Use low viscosity hy guard or hy
tran or standard atf type 3 or 4
Here's a pic of the pump.
