Which MF model do I have?
hartfish
I posted a question about replacing the radiator and fan on my MF 35.
After searching for parts, I'm not exactly sure what I have. It does not appear any of the radiators sold on this site for the 35 match the one on my tractor. See attached photo.
However, after searching through the MF serial number chart on this site, my tractor's SN is for a MF65. (708085)
Any help is appreciated.
[/img]
If you are looking for a positive ID on the tractor model it may be prudent to post a picture of the entire unit.
I think it is a 65 radiator but can't say I'm 100% sure.
That radiator looks repairable. If so, it will be much better quality than anything you could buy to replace it.
With the serial number you provided it's a 1964 year model (it looks like a MF65 radiator). If it has a gas, or LP engine the radiator part # 184525M91. On a diesel the radiator is part # 186733M91.
Thanks for your help.
What confuses me though, is that the serial number (found on the plate attached to the engine block and matched with SNs here on yesterdaystractor.com) seems to be for a 65, but it clearly says MF35 on the plate by the gauges and steering wheel.
Is it possible I have a 65 engine in a 35 body?
I did get it repaired (rather quickly, no less) thanks to your suggestion.
You saved me a lot of money. Beer's on me.
(quoted from post at 10:40:45 08/17/15)
What is the number on the plate below the dash after it says its a MF35 (the tractor serial number should be stamped on that tag).
