Which might be better and why.???
Looking to buy a 4 or 6 row double disk planter to plant food grains between my CRP tree rows. There is going to be some trash but as a rule it will be mostly no-till corn and spray with round up &/or sorguhm. Which would be better the JD 71, the IHC 185 or IHC 295.Or should I look at the JD 7000 or 7100. OR, do you guys have any other suggestions? Thought about a 400 or 800 IHC cyclo but might be over kill.
Thganks, Dan Swanson
The 800 Cyclo will plant where the others won't without all the add-on coulters, etc. Dealr I worked for once said it would plant down a gravel road if you wanted! I have seen them plant in ground so hard it wouldn't close around the seed.
