White 2-105 Shifter Binding
Part Time Pete
I've been having some issues with the shifter on my 2-105 - lately it's been binding, then today it got to where it won't go into second gear. It'll go in partially, but not enough to stay. Any thoughts/suggestions?
Pete
How does the clutch pedal feel? Perhaps the binding is due to a load still being applied to the gears from the engine (if the clutch isn't fully disengaging). It's a simple check/adjustment and could rule out a potential issue.
The clutch seems to be working OK. Another thing it did was when I stopped to check on the baler, I popped it out of third gear, started to let out the clutch and it was still in gear. After some fiddling back and forth between third and reverse, I got it to neutral
Is there top access to that transmission, to possibly see if something's bent of broken, or does it have to come apart?
Pete
You could have a shift fork that has come loose or cracked. You can get the top cover off and see the shifters, it takes some doing , you have to fight the hyd lines. If something has happened to a shift rail you will have to remove the rockshaft housing and possibly the engine. Hope its loose or missing bolts, make sure you loctite them!
