White 2-135 Brakes
MSinNY
My White 2-135 is having some problems with the brakes. The brakes pulse or vibrate whenever the brake pedal is pushed slightly or trying to make a reasonably slow stop. The brakes stop the tractor abruptly with no vibration if I push them in hard and hold down. Pretty much if I try to make a normal stop by applying the brakes lightly, the pulsing is there. Since it happens with both brakes(left & right), I tend to think it may be in the control valve. Any ideas where to start?
Check the inlet there is a orfice in there, and sometimes it works loose and the o ring behind it plugs the orfice. Make sure you tighten the orfice plug properly. Have run into this many times
