White 2-155 Steering Problems
I purchased my white 3 years ago with 3500 hours on it. Looked like a new tractor. When I was driving the tractor home the steering was so loose I couldnt keep it on the road. I would hit a bump and the right tire would start wobbling so bad I would have to stop the tractor and then start driving again. This is what i have done so far, I changed the tie rods and also the spindles on both sides. That took a lot of the slop out but I still have some coming from the steering box. The large nut on the bottom of the steering arm always comes loose. I believe the taper is bad or worn and its not holding itself in place. I am sure this is where the rest of the slop is. Any other ideas on how to change this or what the part is called? I sure appreciate your help!
(quoted from post at 10:28:44 03/02/11) I purchased my white 3 years ago with 3500 hours on it. Looked like a new tractor. When I was driving the tractor home the steering was so loose I couldnt keep it on the road. I would hit a bump and the right tire would start wobbling so bad I would have to stop the tractor and then start driving again. This is what i have done so far, I changed the tie rods and also the spindles on both sides. That took a lot of the slop out but I still have some coming from the steering box. The large nut on the bottom of the steering arm always comes loose. I believe the taper is bad or worn and its not holding itself in place. I am sure this is where the rest of the slop is. Any other ideas on how to change this or what the part is called? I sure appreciate your help!
Did you ever find a fix for your steering problem? I have the same issue and can't keep the nut tight.... Any help would be appreciated.
