The fuel return is leaking on my 2-70 at the tee of the #6 injector. I tried tightening the two side fittings (the rear one has the hose on it), it might have helped a little but maybe not, it's still leaking. The hose going up to the tank looks OK and not leaking. The hose has a crimped steel flare fitting on it if original, is that correct?
The tees and lines are steel flare fittings, is that correct?
Where should I look for the leak and what parts will I need to repair? Thanks.
