Hobby Mark
Having a little problem with my White 2-75. After an hour or so of heavy use, the engine seems to miss a little bit and seems to depower. All fluids are good, not running hot, no visible issues. Runs perfect for the first hour then starts to sputter a bit. Any ideas ? Thanks
Make sure the fuel cap vent is not plugged up. If a gasoline engine, it could be the coil failing. When it begins to sputter, Feel the ignition coil if it is too hot to keep your fingers on it, it is likely the problem. Jim
Thanks. I did remove the fuel cap when discing the other night and it didn't seem to make any difference. Engine is a 6 cylinder Isuzu diesel.
The fuel tank is venting but I have not checked fuel flow from the tank. Of course it is full at the moment. Was thinking I should drain and inspect/clean the
tank.
also check to see if your fuel filter has a banjo bolt on top of it with an orfice to allow the air to bleed back into the return line they will stop up an get over looked as all system don't have them.
